Threads: 43
City: Roseville, MN
Hi all. I need some help finding the model of this radio. It looks like a Pholco speaker, has 2 bakelite blocks in the lower left cotner and the loose tone control switch has a Philco type part number on it. It is a TRF with 4 tubes; 2-77s, 42 and 80. Also the parts are stuffed in there. Just picked it up yesterday for $6.
Threads: 310
City: Kings Park NY
Yes it is a philco chassis. It is a 59 I believe
AC: 4 DC: 1
(This post was last modified: 08-30-2017, 10:10 AM by OldRestorer.)
Threads: 43
City: Roseville, MN
I just checked the schematic for a 59 and it looks right on! Now I need a cabinet.
You guys rule! Thanks.
Rod
Threads: 268
Very similar circuit to the model 84 series just in a pee wee cabinet.
It's a Model 57 chassis. No pilot lamp, and it has an AM/"police" band switch which is loose under the chassis.
Oh, and it is a regenerative superheterodyne, not a TRF.
Threads: 11
City: Bellmawr, NJ
WELL ,,,you asked,,,,you got the right answer from Mr.Ron,,,,,he KNOWS his stuff,,,,CHEERS
Threads: 43
City: Roseville, MN
Ron, Kenneth - Thanks, I appreciate the input. Glad you noticed the dangling switch. I thought it might be a tone switch. Odd place for a band switch!?
Rod
The 54, 57, and 58 had it in back, like that. It's just a simple SPST switch that connects a 325 pF capacitor into the secondary of the antenna coil. (In model 54, the switch shorts out part of the antenna coil secondary.) This allows the set to (sort of) pick up frequencies above 1500 kc; this band of frequencies was used in ye olden days by police departments.
Model 27-84 BUZZ?Humm?
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Philco 630csx power cord
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
On K2, pins 1&2 are shorted. On K4, Pins 1&3 are shorted. Others are OK. - your 0.047 caps are fried in both
Th...morzh — 10:40 PM |
Hello Tynwald ,
I would not use that plug and what I would do is us Some of this cloth covered wire !
you can also buy...radiorich — 10:28 PM |
There are currently 2758 online users. [Complete List] » 2 Member(s) | 2756 Guest(s)
