41-250 knobs and bezel
i sent a message off to a gent about knobs and a bezel, no answer. anyone know of a source for those parts. im restoring this old beast, garage sale 4 bucks.
tnx fer any info. ron
Welcome to the Phorum!
Icon_wave
See the Resources listing for knob sources...
http://philcoradio.com/phorum/showthread.php?tid=14950 and other supplies.
Renovated Radios has the escutcheon, although not the brass piece with the lettering on it.
Tnx mucho for info, will ck it out. Tubes on way, hope soon to listen to the old gal. Ron
Don't forget before listening to these old radios you really need to replace the film capacitors . They are not safe as old as they are. Good Luck with it all..
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2599 online users. [Complete List]
» 1 Member(s) | 2598 Guest(s)
