48-482 no FM
That's a beauty!
I don't know, offhand, what tubes that model had but there are often different tube sets in the different code numbers.
Rule of thumb: Whatever model/code number you can find a schematic for is the radio you don't have.
Rob
Quote:Whatever model/code number you can find a schematic for is the radio you don't have.
Murphy strikes again.
The schematic I downloaded from Radio Museum had the right tube lineup, and was easier to read, but used different component labels, which made it hard to use.  Thanks to this forum I was directed to the better resolution one in djvu format.
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 3950 online users. [Complete List]
» 1 Member(s) | 3949 Guest(s)
