Westinghouse model?
Any ideas about this Westinghouse?
I bet it starts from WR Icon_smile
looks like a WR-203
The model probably starts with a WR, unless you accidentally purchased a Canadian Westinghouse set, but it doesn't look like one of those.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2106 online users. [Complete List]
» 1 Member(s) | 2105 Guest(s)
