Please ID
[Image: https://farm5.staticflickr.com/4497/3736...c363_b.jpg]
Says on back Made in Italy
[Image: https://farm5.staticflickr.com/4509/2422...1bea_b.jpg]
Says on front Made in Germany-West
Thanks
Skip...
Both Grundigs, I'll wager. The top looks very similar to a Grundig Type 88. Bottom one looks like a Grundig-Majestic something-or-other.
Greg
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2123 online users. [Complete List]
» 1 Member(s) | 2122 Guest(s)
