Mysterios Model 650RX(?) chairside
Well, I apologize as being offended, ticked off, or exasperated was the farthest thing from my mind! I am truly sorry if my post (I didn't send an email) came across that way.
And hey, if you're happy with it as is, then there's certainly nothing wrong with that. But do be aware that the fidelity will suffer from the placement of the speaker.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2521 online users. [Complete List]
» 1 Member(s) | 2520 Guest(s)
