Substitute Tubes - Infradyne Super
PART II
Substitution of 01A and UX 199 tubes in a 1928 Remler Infradyne Super:
https://www.russoldradios.com/blog/remle...bstitution
I have another big project to work on so this will have to do for now.
Russ
P.S. If you haven't read Part 1, it makes more sense if you do so.
Russ,
  The control panel of that Remler reminds me of the instrument panel of a 1920s car.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2206 online users. [Complete List]
» 1 Member(s) | 2205 Guest(s)
