Threads: 9
City: Albany,NY
Terry what are the proper connection points for the #12, 27K ohm resister ? The schematic is confusing and my interpretive skills are weak. Looks to me like pin 5 on #9 and pin #3 on the 7B7. Then a connect from pin #3 on 7B7 to pin #5 G3,5 on the 7A8.
Threads: 268
Perhaps this will simplify it for you.
The HV is directly connected to the bottom on the output transformer, SG of the 50l6 (pin4), bottom end of 20 (1st audio plate resistor), bottom end of 13 which in turn feed the plate of the IF amp, bottom end of 10 which in turn feeds the plate of the 7A8 mixer, pin 5 of the osc coil, and the left side of 12. The right side of 12 feeds the SG voltage to 7B7, grids 3 and 5 on the 7A8 and is bypassed thru 11 back to B-.
Threads: 9
City: Albany,NY
Hi Terry, just found a dead short on the oscillator side of the tuning capacitor. The stator is shorted to chassis even when the variable cap is wide open. Have to check how its isolated from chassis. Was hoping not to have to remove from chassis. We'll see.
Elfiself
Threads: 569
Are you sure you are not seeing the low resistance of the coil 9 across it?
Threads: 9
City: Albany,NY
Well I just spent an hour with a 15X glass, inspecting the fins and couldn't find a problem. What do you suggest to verify the coil effect?
Threads: 268
< What do you suggest to verify the coil effect?
Disconnect the wire from pin 2 in the coil. This will break the ground connection thru the coil. With that disconnected the tuning cap should read open.
Threads: 9
City: Albany,NY
Threads: 9
City: Albany,NY
Looking at the 42-PT7 schematic can you help me identify the pin numbers of the 7C6 diodes. Is there some convention to identify which is #5 and #6
thanks
Elfiself
Threads: 569
Threads: 9
City: Albany,NY
Yes but which is which on the schematic itself. I don't know what to wire to which pin.
Threads: 569
Here's the thing: choose any diode plate of the two to be 5 and the other - 6.They are the same and it doesn't matter if you reverse them.
Threads: 9
City: Albany,NY
Thanks morph. This is what I suspected.
Larry
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
