Ham Radios
I'm sure there are some ham radio operators here On the Phorum. Does anyone have any recommendations for a decent but not expensive handheld ham radio transmitter/receiver? My stepfather has a big setup, but due to his age and health issues, needs something small and simple. Thanks in advance for any suggestions.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
https://baofengradio.us/baofeng-uv5rv2-black.html
Have hear these are pretty good and you can't beat the price. Setting up the memories is tricky so you may have to help out.
I have to agree with that. You can't beat Baofeng for analog FM. Use CHIRP to program them, it's free.
Clinton VE7KNL
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 3006 online users. [Complete List]
» 2 Member(s) | 3004 Guest(s)
