Threads: 569
Its really dirty and the transformer is rusty.
Kirk mentioned smoke.
I did a superficial cleanbgc and took out the tubes.
The rectifier's bad.
Then before I went to recap I checked the transformer. I only checked the rectifier filament voltage, seems good.
Did the recap. One cap in the RF chassis took a bit of work, the backelite cap was easy - put Y2 caps n it. Kirk did the electrolytics.
The resistors seem ok, even the wirewound, except the divider 22, 23 and 57 - all seem to be twice the value.
Need the speaker. The speaker wires are really frayed and twisted together. I wonder if this made it smoke.
So far this is it.
Threads: 569
Kirk
I will really need that speaker.
I could try to temporarily replace the field with a 1K wirewound resistance and use a PM but that's inconvenient.
Oh....installing those gommets at the side of the RF chassis is a real female dog.
Threads: 569
Found two more caps I missed while changing the power resistors, changed them too.
Now I reeeeaaaaaallllly need a speaker.
The problem with replacing the field coil with a resistor is that I likely won't have a PM speaker with an output xfmr.
Threads: 42
City: Jeffersonville
State, Province, Country: PA
Hi Guys -
When should Y2 caps be used as opposed to the yellow Mallory versions?
Threads: 569
Any time you put a cap across live mains power, you should use at least X-rated cap, and every time the cap crosses between the Mains and the chassis (or any touchable by user metal part) - Y-cap.
Otherwise these caps are not necessary.
Threads: 42
Threads: 569
So....I found two 2.2K 5W resistors which in parallel give exactly the resistance of the field coil, and with an output xfmr from Philco 90 for the 47 tube which is the same 7K as for 6F6,which is still wrong as my PM speaker is 8 ohm and philco 37-610 is probably 0.7 ohm or so.....I plugged it in and after swiching to the BC band pulled in the local station and a couple of others when holding antenna input with my hand.
Needs alignment but otherwise is ok.
This is the chassis that smoked according to Kirk. Well, the speaker wires were bare and twisted together. I wonder if this possibly could be the reason?
Threads: 569
This is how I connected it.
I have aligned the IF and then BC padders and trimmers.
The sensitivity increased greatly, especially after BC algnment.
The Jersey Shore station is exactly at 1160AM.
I this will be it. If Kirk has the speaker after all
Threads: 2
City: Madrid, Spain
Just I have restored one speaker for this same type of radio and the Voice coil (original) was 1,7ohm (I supose 2 ohm will work)
Just in case you need this info.
Good job and keep going
Threads: 569
Jeepeto
Thanks. My goal in this particular case was to give the radio a temporary speaker, considering Kirk did not provide one - only the chassis  , to test the radio and to align it.
Which makes it not super-important as the original speaker eventually will be connected (Kirk claims he found it). Even though the impedance is several times that of what it should be, it still works just fine.
Mike.
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
