Stewart Warner R-137-A
Hi Terry,
So that 16 is an E-cap. Kinda wondered as it is polarized.
I will have to look and see what that other cap is attached to.
Catch ya later.
murf
Yes the + connects to the cathode of the tube and - to the chassis.
Correct again Terry,
Found a schematic and the .1 mfd cap goes to one of the 6K7 tubes.
Replaced it with a new cap and attached the flexible resistor and it seems that it took care of the static problem.
Will have to play it for a while and see.
Thanks again Terry.
murf
There are currently 3562 online users. [Complete List]
» 1 Member(s) | 3561 Guest(s)
