I wish I had a cabinet for this 96
A good friend of mine  was leaving Calgary for the east coast and he could not take this with him.
So he gave it to me.  It is a Philco model 96 and it works fine, except there is no cabinet.
 I have so many radios now that I don't have room for it.
    I wish some of you guys were closer so you could make use of it. I may just put it in the garage  as a rat radio.
 Dan in Calgary
   Living in Calgary Alberta
I have the 96 chassis in two different cabinets- 296 with phonograph, and the Concert Grande. Very well built chassis!
Brad
Hay Lakes, Alberta
There are currently 10284 online users. [Complete List]
» 2 Member(s) | 10282 Guest(s)
