41-221c
I found a Philco 41-221C, it looks complete, but the grill is missing. Is there some place that remakes them? Thought about trying to make a wood grill for it what do you all think?
Michael
Philco 41-295X 4 band radio.
I'm 67 years old, in north Idaho.
Kirk (OldRestorer) had several of these grills made. He did have an ad in the For Sale or Trade section of the Phorum (bottom of the page on the Phorum home page), but the ad is no longer there so he may have sold them all?
Sorry,
I stopped selling them. Only have what I am keeping for the future.
Kirk
Thanks for the reply, will have to think about it see what I want to do.
Michael
Other later models used plastic. If you can find a junker you can steal the grill.
Kirk
I have a beige - light brown one     but not cheap
There are currently 10539 online users. [Complete List]
» 2 Member(s) | 10537 Guest(s)
