Photo test
I am going to try to put photos of my 37-604 on Flickr so I can share them here. This is a test only, moderator feel free to delete Icon_biggrin
[Image: https://www.flickr.com/photos/23674410@N...ed-public/]
[Image: https://www.flickr.com/photos/23674410@N...331317.jpg]
[Image: https://www.flickr.com/photos/23674410@N...res/5Br53w]
[Image: https://www.flickr.com/photos/distortion...res/j3u2Z5]
[img][Image: https://farm9.staticflickr.com/8472/8083...d1bc_z.jpg]Distortion by rtalfa, on Flickr[/img]
Got it!
Russ
That tube will work better if you get that dude out of it.
That's an awesome photo. It's like the "ghost in the vacuum tube".
There is already such a think as a ghost in a tube, it's called gas, and secondary emissions, it's like having a poltergeist in your radio.
I don't know if he has "gas" but he sure does look uncomfortable!
I guess I will leave him in there, the radio sounds fine when he is asleep. I'll try not to wake him up.
Russ
There are currently 10813 online users. [Complete List]
» 2 Member(s) | 10811 Guest(s)
