Sparton 601-FR schematic needed.
Anyone have this schematic? Neither the 601-B nor the 601MS are the correct ones. Already checked Ryders and Nostalgiaair. Thanks.
There are currently 10454 online users. [Complete List]
» 3 Member(s) | 10451 Guest(s)
