Next Restoration Project- 1929 Victor R-32 Radio
I had an RE-45 years back and I foolishly sold it when I got the Majestic 181 radio-phono. The RE-45 was the best TRF radio I ever owned and picked up channels quite well. I know where there are two R-32's and even some parts sitting right now, but the owner would probably want a good bit just for the tubes in them and my late friend was the only one I knew who could get them to work. Also, we had issues with bad speakers in these, mostly issues with the solid disk spider getting warped.
There are currently 10322 online users. [Complete List]
» 1 Member(s) | 10321 Guest(s)
