Dial Zenith model 211-52
Hola, necesito ayuda para enrollar el dial del modelo de radio Zenith 211-52, sería un buen diagrama gráfico.
Gracias.
http://es.tinypic.com/r/8wf7vd/9
[Google translation added by admin below]:
Hello, I need help to scroll the dial of the Zenith radio model 211-52, it would be a good graphic diagram.
Thank you.
There are currently 11390 online users. [Complete List]
» 2 Member(s) | 11388 Guest(s)
