Philco 90 Case Histories and Solutions
For all models, single 47, push-pull 45s and 47s.
and the last two pages
Those who would want to know more:
Radio Troubleshooter's Handbook
by Alfred A. Ghirardi
https://archive.org/details/RadioTrouble...rsHandbook
I found a copy 50 ya. the most used and worn book in my radio library. Invaluable information on all those sets when they were "new".
Hard copies are still around, seen on Amazon.
Chas
Pliny the younger
The speaker table error?
Philco 70 antenna lead
There are currently 7130 online users. [Complete List]
» 3 Member(s) | 7127 Guest(s)
