Philco 60 - Problem with Short Wave/Police Band
Your right about that resistor. ...I'm fixing the drawing as I type.... Icon_redface . Thank you for the help sir I do appreciate it.... You are a gentleman and a scholar. Icon_biggrin
Danny
I see I never did report back with the correct number of turns in the 60 oscillator coil primary - my apologies.
I'll give details on both coils while I'm at it.
Model 60 Antenna Coil
Primary (outer) winding - 4 turns, CW, bottom to top, 38 gauge
Secondary winding (on the coil form) - All CW, bottom to top. 25 turns from beginning (lug 1) to lug 3. 129 turns from lug 3 to lug 2. 20 turns from lug 2 to lug 5. 32 gauge works well for this winding.
There is also a separate winding inside the coil form, mounted at the top. It is approximately 250 turns, 38 gauge.
Model 60 Oscillator Coil
Primary (outer) winding - 18 turns, CCW, 38 gauge, bottom to top, lug 3 to lug 2
Secondary winding (on the coil form) - All CW, bottom to top. 15 turns, lug 1 to lug 4. 90 turns, lug 4 to lug 5. 22 turns, lug 5 to lug 6 (on top). 32 gauge is OK for the secondary.
To determine which lug is lug 1, 2, 3, etc., hold the coil by the large mounting lug and count the small lugs clockwise from left to right.
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 3820 online users. [Complete List]
» 1 Member(s) | 3819 Guest(s)
