Philco Model 114 or 506 Chassis Confirmation
Hi All,
Got this nice Philco chassis that  I would like to positively identify.  From my findings I would think it to be from a model 114 or 506.  The output tube that came with the chassis is a type 41 (wrong?).  The dial scale is part # 27-5065.  Just want to verify for proper ID for storage tagging.  I've never seen a model 506, rare?  Nice piece of furniture!
Thanks in advance
Danny in Cleveland
Hi Danny and welcome,
Your chassis is a model 144 code 126.
http://www.nostalgiaair.org/Resources/137/M0013137.htm
91H Code 126 Restore
There are currently 3692 online users. [Complete List]
» 1 Member(s) | 3691 Guest(s)
