Philco PT-25--BIG MESS
Ron, I understand..Not blaming Chuck.. I'm sure that was all he had.. But I was hopeing he had more..
This thing is such a mess that I need as much info and parts layout I can get..Otherwise its going in garbage..
That would be a shame as the Case is really in great shape.. But getting frustrated
Skip
I have a unrestored PT-30 I can shoot a pict of wiring. I believe tube lineup is same.
Tom
Tom, Ok thanks .. I will send you a PM with my email address..
Thanks
Skip
Still changing wires.. found many more crumbled.. looks like a complete rewire job.. NOT FUN..
Keeping me busy on these Long Snowy Nights.. Supposed to get 3-6 inches more tonight..
Skip
That's what they promise.
It is mostly raining here now but looking like a bit of snow while it is falling, though it is melting while falling.
Ok I have a question.. The Cap across the AC line Part 25 Says its a .04 Should that be replaced with a Y2 or X2 cap.. I have a X2 at .047.. I know I can probably due away with it also..
[Image: https://farm8.staticflickr.com/7912/4733...ca82_b.jpg]
What do you guys think ?
Skip
That's FBOM. It's just there to filter rf noise out before it get into the set. These days there's a lot of noise so not all that effective.
(03-09-2019, 10:31 PM)Radioroslyn Wrote:  That's FBOM.
Я этого не понимаю. What is FBOM? Icon_think
Ham logo Fine Business Old Man.
In short OK.
Similar to GLOM
Good Luck Old Man
Ok, Finished up the wiring .. Not the greatest job.. But radio works Great..
[Image: https://farm8.staticflickr.com/7921/4672...62a4_b.jpg]
When first powered on I had terrible motor boating across the band.. I forgot to Ground 2 of the tubes.. The 7B6 and 7B7.. After grounded set works with NO hum and no more motor boating.. On to alignment..
Skip
Looks good!
Looks pretty tightgly packed under there, nice work.  Icon_smile
Here is the finished radio.. Looks pretty good . Plays great..
[Image: https://farm8.staticflickr.com/7862/4744...6555_b.jpg]
On to the next..
Skip
Looks very fine indeed. So patience paid off! Good job! Icon_clap
paul
Yes. Fine job, Skip, fine job. Icon_thumbup
91H Code 126 Restore
