Schematic GE-50-C
Good Morning,
I am looking for the scheme of the General Electric 50-C radio model.
Thanks in advance.
Regards,
Ferran
You might want to post a picture of it as the US model may be different than an export model.
According to Radiomuseum, info available in Bietman manual Vol.7, p.46.
Bietman manuals available on americanradiohistory.com
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Scheme found !!!!
Thank you
Important note, in case someone looks for the scheme:
The GE-50 model is missing. Peró model GE-50 is equivalent to RCA-28. And the latter if it is in Riders Radio Collection.
There are currently 8930 online users. [Complete List]
» 1 Member(s) | 8929 Guest(s)
