41-250 allignment question.
Hi folks. Recently aquired a Philco 41-250 "log cabin". It is recapped and I am about to do the re-allignment. Downloaded the schematic from Nostalgiair. The first step is to adjust the compensators in the order of 35A etc, but nowhere does it show a 35A. Where is it?
Hi Phonofilia,
You might have better luck with the Philco 1941 RMS Year Book service info:
https://philcoradio.com/library/index.ph...year-book/
The 41-250 section says to refer to the 41-280/41-285 documentation for alignment.
Thank you very very much!
91H Code 126 Restore
There are currently 2553 online users. [Complete List]
» 2 Member(s) | 2551 Guest(s)
