Philco 48-482 code 121 tube layout..
I have a Philco 48-482 code 121 that the tube layout has a 7B6 in place of a 6sq7...The tube that is in the rado is a 7B6 and the layout shows a 7B6.All the Schemetic info I have found on this radio show a 6SQ7 there.Was there a production change or something and where can I get a schemetic that has the 7B6????Thanks in advance....
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 3600 online users. [Complete List]
» 1 Member(s) | 3599 Guest(s)
