Atwater Kent model 89 3rd type questions
First off Merry Christmas and Happy New Year to all!!
Has anyone worked on an AK 89?  I have a few questions.
http://www.nostalgiaair.org/pagesbymodel...001519.pdf
In the filter choke unit, there is choke #1(480ohms)  #2(1500ohms)  #3(90ohms).  With the wiring in my set the colors don't match up to the chokes.  #2 and #3 are flipflopped.  So the white wire (which was supposed to go to #3)is going to #2 in my set and the red wire is going to #3.  As you can see these values were written in freehand so could they be flopped?  Or should I just go with what the wiring was when I found it.  This set had been worked on before.  A 10uf electrolytic was installed in place of the 2nd 2.3 cap in the filter cap unit under the chassis.
Also If anyone knows the fuse size for this radio by the on-off switch.  Mine was destroyed but it looks like maybe a 3 amp.
One more thing if anyone worked on one of these, is there an easier way to restuff all the bypass cans?  Mine are all rivetted in.  Just wondering.
Thanks for any consideration in advance!!
Dick
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
There are currently 5485 online users. [Complete List]
» 1 Member(s) | 5484 Guest(s)
