1931 Westinghouse WR-10 Tombstone Radio
Hello Everone, recently I was given a 1931 Westinghouse Model WR-10 Tombstone Radio which when I first got it that cabinet was shot but the guts were still good on it (the radio was found in an old abandoned farmhouse that the roof had collapsed on it 20 years ago and the radio had sat in that house all that time which is why the cabinet was basically rotted to the point that it was falling apart).
Anyways I had bought a new cabinet for it on ebay for $30 plus shipping and cleaned up the chassis and replaced some a couple of bad paper caps in the chassis and the original cloth cord as the cord had a break in it somewhere that caused it to not power on when it was plugged in with a brand new cloth cord (basically a modern rubber cord with a cloth sheathing around it), and plugged it in a turned it on, and sure enough the radio worked like brand new still even with its original dry electrolytic filter capacitors intact, and the radio is super sensitive, as I was able to some major DX'ing on it at night where I was picking up stations from all over the country including an oldies station from Ontario, Canada, and all I was using was a 30' length of zip-cord for the antenna that was stretched out across my basement and clear upto the kitchen upstairs.
I have some pictures of the unit in question posted below.
Sorry about the poor lighting in the pictures, my basement isn't very well lit.
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
There are currently 5488 online users. [Complete List]
» 1 Member(s) | 5487 Guest(s)
