Stewart Warner model 1845 tuner operation
Hello fella's,
Wondering if anyone can tell me how the manual/electric tuning control is supposed to work on this radio?
It is the R184 chassis, and it has a large brass outer portion which is pushed in for electric and pulled out for manual tuning.
But when you pull it out it ends up completely covering the inner 1/4 inch shaft that has the flat on it.
Hoping someone here has one and can fill me in on the operation of this control.
Looks like quite an elaborate mechanism.
murf
I have a Stewart Warner console  model  409 with 15 preset push buttons.
 If your chassis is similar, the instructions for setting up the preset might be the same.
    I think that the presets might be very close in operation.
     It took me a couple of years to get this information, but I could sent it to you if you like.
 It covers all the small adjustments,like how far apart certain contacts should be  ,etc, etc.
    Here is some information.
 Dan in Calgary
   Living in Calgary Alberta
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
