philco model 111 resistor help
can,t find resistors with right ohms ones i need are 13,000 250,000 17,000 25,000 can i run two in series 10,000 3,000 ect thanks denver. Icon_confused:
Use the closest modern equivalents with the right wattage as replacements. Those original resistors only had a 20% tolerance anyway so if you ghet within 10-20% you will be ok.
Here is a table of available modern values:
http://www.radio-electronics.com/info/da...values.php
thanks a bushel and a peck mr. schwark
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
