Philco 39-7 alignment
Hi guy's, on the schematic for alignment it shows using a .1mf (uf) and a 100mf (uf) for dummy antenna. I don't have a 100uf cap except an electrolytic type. What can I use instead of the 100mf.
Thanks
Jim
Spring Lake MI
Methinks you missed a m it's 100mmfd.
+1 What Terry said
Gregb
Thanks guy's for your reply. I did use the 100pf, but the schematic actually shows 100mf and so did other models I checked. However the later ones (models) show 100mmf. I think they must have had a miss print on some of the early models.
Thanks again..........
Jim
Jim
Spring Lake MI
91H Code 126 Restore
There are currently 2577 online users. [Complete List]
» 2 Member(s) | 2575 Guest(s)
