Philco 41-280 (121)
I am down to the last pieces,
Does anyone know the replacement #'s on the radiodaze.com website or the specs on the 41-280 Capacitors and potentiometers.
Parts values are on this diagram: http://www.nostalgiaair.org/PagesByModel...013415.pdf
Model 27-84 BUZZ?Humm?
Hello Bruce, First all do mean a 37-84b ? Did you take any before and after pictures ?radiorich — 01:59 AM
Philco 630csx power cord
There are currently 3769 online users. [Complete List]
» 1 Member(s) | 3768 Guest(s)
