Help to repair the Philco Mystery control spring
Hi.
I am restoring my Philco 39-116, and the Mystery control.
In my Mystery control, the dial does not return, because the spring is broken and I only have a little bit.
Does anyone know its length and how it fits inside the pulley, as I only see a small 1mm hole.
See the pictures.
Many thanks.
Regards,
Carlos
Regards from Portugal,
Carlos
Chuck’s Philco Repair Bench has some detailed info on the mystery control. Don’t know if it discusses the spring or not. https://www.philcorepairbench.com/philco...y-control/
Hi.
Thanks Bob for the link.
I found a spring in ebay and now the _Mystery control work perfect  Icon_biggrin
[Image: https://i.imgur.com/HctQor2.jpg]
[Image: https://i.imgur.com/xRowf4Y.jpg]
The video    https://youtu.be/c10beZEvYr0
Many thanks
Carlos
Carlos
There are currently 4070 online users. [Complete List]
» 1 Member(s) | 4069 Guest(s)
