Threads: 24
City: LAVERN-SUBIRATS
State, Province, Country: ESPAÑA
Good Morning,
For those who may be interested.
I have come across some cut Philco coils. I pass the data in case someone has the same problem. The repaired radios work perfectly.
PHILCO 89
PRIMARY OSCILLATOR 25 SPIRES WIRE GAUGE 39
PRIMARY RF 12 SPIRES WIRE GAUGE 39
PHILCO 37-84
PRIMARY OSCILLATOR 14 SPIRES WIRE GAUGE 39
Cheers,
Ferran
Threads: 1
City: WOODSTOCK
Thank you for the information!!! Agradecido!!
Threads: 19
City: The Motor City,Detroit MI
Anybody know if it's the same for Philco 90? I have one in the queue with an open coil.
(This post was last modified: 06-18-2020, 12:39 PM by Kestas.)
Threads: 268
Perhaps the might be a good idea to start a section in the Library addressing models and coil rewinding? More specifically what coils and number of turns/wire ga. Members can fill in the blanks as to what they found that works.
Threads: 24
It is different. I am attaching you web page. There you will find the answer.
https://www.philcorepairbench.com/rewind...-rf-coils/
Threads: 24
Radioroslyn:
It seems perfect !!!!!!!
I wanted to propose ........
Threads: 268
We need to get admin on board to make it happen.
Threads: 214
City: Seattle
State, Province, Country: WA
This is a great idea guys! Adding a section to the library is easy.
It would be a bit harder to allow contributions to it - I will se what I can do.
Threads: 268
Could be posted here and vetted and then admin could add to the library. This would help eliminate spam and such.
(This post was last modified: 06-18-2020, 10:23 PM by Radioroslyn.)
Threads: 214
City: Seattle
Here's the new Library page:
https://philcoradio.com/library/index.ph...lco-coils/
If there are any other old threads with coil details that you know about please let me know and I'll add them there as well.
Threads: 268
Philco Model 600 oscillator coil:
If anyone needs the data it's primary is 125T of #36G & Secondary is 25T of #36G.
Threads: 214
City: Seattle
Thanks Terry! Model 600 oscillator coil details added.
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 3871 online users. [Complete List] » 2 Member(s) | 3869 Guest(s)
