RCA 1X591 hum problem
Interesting problem. great advice from the experts. While a little risky to modify the wiring, I usually try to create a "Mecca" type of ground. The 12SQ7 / 12AV6 Detector / First Audio Amp heater and cathode are referenced to "ground" (actually neutral or the common "B-"), and usually by capacitor but sometimes directly, to the chassis in these radios. I will usually find a way to connect the negative of the filter caps, (if they are referenced to B-), the cathode resistor of the Power Amp (50L6, 50C5, etc.)and the heater, cathode of the 12SQ all to the same point, extending the "ground" to the rest of the circuit. This is reminiscent of how "Hi-Fi" manufacturers built their amplifiers. I have a 1947 "Philharmonic" AA5 Radio built in this manner.
Remember that even on a circuit as simple as the audio circuit of an "AA5" radio, lead dress is important. Another consideration is to keep the coupling capacitors away from the heater wiring. Original caps were marked "outside foil". These should be referenced to B- for bypass caps or the plate circuit of the stage being coupled to the next stage for interstage coupling caps. Newer caps seem to be not made with "outside foil" so care should be taken in their installation and "dress".
Like Ron Ramirez, "Phil's old radios" and others, I am a big proponent of rewiring the radio using a polarized cordset and wiring the power switch to the "Hot" side instead of the "Neutral" side of the power line for increased safety. However, this act may also increase hum slightly, and may be the reason why the manufacturers of series string radios switched the neutral instead.
John
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
