Horseshoe Pick-up Coil Question
Hi, would anyone happen to know why this coil has 4 leads?  I was expecting only 2.  Pic only shows 3 since one is broken.  It's from a 1930's era horseshoe magnetic pick-up.  Asking here since I've been following the rebuilding guide which has been very helpful.
Also, does anyone make new coils like this? Thank you!
Eico 232 VTVM Schematic
There are currently 6728 online users. [Complete List]
» 2 Member(s) | 6726 Guest(s)
