Reproduce Tube Layout Paper Labels?
The 70 Chassis is cleaned and painted and looks good but I haven't done anything to tube shield yet; it could also use a coat of paint as it has rust. The paint will be a darker gray and I think I will try a hammered finish. Problem is; It has a tattered tube layout label that has a couple of corners missing. Does anyone make repro labels; or what is best way to go about maybe printing one and using adhesive to apply to the new paint surface? Ron, sorry if maybe this is better in another forum . Thanks Bill
Someone was selling reproduction labels for Model 70 and 90 sets on eBay a year or so ago.
You could make your own. Just scan the label you have and clean it up in your favorite photo editing software. Then print and glue.
A few of us have discussed the possibility of making scans of various labels available here, but I have not had time to work out the details.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
