Philco 46-480 Chassis issue
Hello:
I have a 46-480 chassis that needs a new AM/FM IF can. My repair tech says the can is reading open on both circuits and he is not able to repair / rebuild the can. I'm thinking the options I have are to find another donor part, find another chassis with a can and hope it's good or find someone who can rebuild the existing can.
There is a part number printed on the side of the can. it reads 32-4704 and then there is this number 294-610.
I am open to any suggestions.
Thank you for reading my post
Phil
pcmradioguy
Hi Phil and welcome,
 Try placing a want ad in the Ad section and over on the ARF site.
There are currently 3946 online users. [Complete List]
» 2 Member(s) | 3944 Guest(s)
