Chassis swap
Can anyone tell me if I can put a PT-65 chassis into my PT-61 cabinet if I remove the preset assembly? My PT-61 had an incorrect chassis in it when I bought it. It looks to be the same design of chassis just with the preset assembly wired in. Looks like after comparing both wiring diagrams I could just remove the preset assembly and move a couple wires and it would be the same.
There are currently 4135 online users. [Complete List]
» 5 Member(s) | 4130 Guest(s)
AvatarAvatarAvatarAvatar
