So! Am I a big dumby?
I should have known better. Icon_rolleyes I am looking to get a 37-610T bullet radio, and bought a servive manual ahead of the radio. Upon looking closer, I see the manual is to a 37-610 not a 37-610T. Icon_redface So are these the same chassis or do I get the big DAH! award? Icon_lol
tractorforum.com *** I reserve the right to be wrong
Don't worry, it is the same...that is, unless you have a Service Bulletin for a 37-610 Code 121 or 122, and end up owning a 37-610 Code 125 or 126.
The main difference is that the RF units are different. Also, if you want a table model it will be Code 122 or 126 (the rectifier tube is behind the power transformer, not mounted on top of it as in Codes 121 or 125).
Thanks Ron. I thought that might be the case but wasn't sure. It only cost me a few bucks, and it is an original copy. Now I just gots to locate a radio. Icon_biggrin
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 3644 online users. [Complete List]
» 1 Member(s) | 3643 Guest(s)
