Threads: 110
City: Omak
State, Province, Country: WA
Hello everyone,
I am working on Some RCA 1950s Phono's and looking at buying some that tape used on motor windings ?
As you can see in my Photo how I used heat shrink and spliced the wire but don't really care for it
I thought why not just remove the tape and do a better job and add new tape
Sincerely Rich
Threads: 562
No photo here.
Threads: 110
City: Omak
Here is that Photo everyone,
Image(s)
Threads: 112
City: Medford OR (OR what?)
Are you asking about Friction Tape?
Threads: 110
City: Omak
Hello Phlogiston,
is that what they call that special tape used on transformers and motors ?
Sincerely Rich
P.S. I did see this tape 3M 28 White Acetate Cloth Tape, 1" Width
Threads: 110
City: Omak
Hello Everyone,
here is a photo of the tape i was looking at !
Image(s)
Threads: 112
Friction tape is black cloth tape. That looks more like masking tape which would look pretty close.
Threads: 415
City: Boston
Friction tape a staple of old style electric work, might be better than what was pictured. Used to use it on Hockey Stick blades.
Was a good supply at our house as dad worked at utility.
Threads: 110
City: Omak
Hello Phlogiston,
Well 3M™ 28 is a printable white Acetate Cloth Tape with thermosetting rubber adhesive used for electrical insulating. This tape absorbs resins and varnishes and offers excellent conformability in coil wrapping applications.
It is electrically rated for 2500volts and 221 degrees F.
Threads: 562
Cloth tape with funny smell was pretty popular in Russia.
Threads: 268
+1 Russ
I've got some yellow masking tape that looks pretty close. But would probably burst into flames and burn your house to the ground![Image:
https://philcoradio.com/phorum/images/sm...wisted.gif ]
Threads: 13
City: Greenwood
State, Province, Country: Delaware
This is why I read the phorum
Threads: 110
City: Omak
Hello everyone,
thanks for all of your ideas .
sincerely Rich
Hello Tim,
Sincerely Richardradiorich — 01:55 AM
Hello Tim,
Sincerely...radiorich — 11:07 PM
Hi Dan,
I can't explain this specific resistor but I have seen the use of a switch to apply B+ voltage to screen gri...RodB — 09:36 PM
And I suspect whoever repaired it, wanted to re-use old transistors' pin stubs in o...morzh — 09:24 PM
Hello Tim,
bk1077bradiorich — 09:01 PM
I'm a little befuddled on this one. Should X5 and X4 be tied together like this? It looks like someone added this at so...R3Sons — 07:33 PM
