V-belts used for volume control drive in 41-616 and 42-1016
Hi folks,
A friend of mine needs replacement V belts to use in both Models 41-616 and 42-1016 for the motorized volume control.
He says the circumference is 7-1/2 inches, 3/16" in diameter. They are around 1/4" wide at the top and 5/32" at the bottom.
Does anyone here have any ideas?
Thanks.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1942 online users. [Complete List]
» 3 Member(s) | 1939 Guest(s)
