Deft Lacquer Warning Lot: Nov18-20-19968
I just finished unboxing a couple of gal. of this GLOSS lacquer that I purchased through Amazon.
It is about 3 time as viscous as it should be, so it requires a lot more thinning. If you are spraying, this is really a good deal. About 3 for 1 in materials - as long as you know to reduce it FIRST.
If you are brushing it ("no thinning required"), I think it is going to be a real sticky mess and way too thick.
Also, A gal of gloss lacquer should be pretty much clear all the way to the bottom - this stuff is not. So it is easy to verify visually.
So be aware.
Russ
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 3386 online users. [Complete List]
» 1 Member(s) | 3385 Guest(s)
