Stewart Warner 176 assistance
http://www.nostalgiaair.org/Resources/885/M0029885.htm
I recently bought this Stewart Warner 176 locally and just wanted to get a couple of items cleared up. I’m new to this and this radio has been worked on before which complicates it for me. The fellow I bought from said he was new as well and gave up on the restoration.
R8 is 100,00 and R12 is 500,000. Are they are both potentiometers and if they are, how to measure them properly? Should they be replaced if they’re too high/low?
How would I find a value for R20, it measures 9.600K, I traced it back to a resistor on a large terminal board, it’s brown black but the multiplier has been scrapped off. Is 10K a reasonable value for this resistor.
The last item is there is a remote volume control on the schematic. It didn’t come with one so is that an issue? I haven’t plugged this in yet and won’t until I finish with caps and resistors.
R8 is the tone control and R12 is the volume control. R12 is the audio gain vs R19 control the gain of the rf amp tube. Generally I find that controls don't drift in value much unless there's a is a large amount of current passing thru them. This can cause heating which in turn can cause drift in the value. This isn't the case in this application.
But wear, dirt, and cracks in the resistive strip could be a problem. This will make it intermittent. Best way the check it is to use an analog ohm meter connected from the wiper to ground side of the control. The needle on the meter should move smoothly as the full range of the control is adjusted.
9.6K or 10K seem reasonable for R20. It supplies the screen voltage for the osc section of the 6A7. I might revisit it if the there is a problem getting the osc running.
On the remote volume control ground the white. That will restore the circuit so that the rf amp will work properly. Without doing so the rf amp is disabled and the sensitivity will suffer badly.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 5471 online users. [Complete List]
» 1 Member(s) | 5470 Guest(s)
