01-25-2006, 10:41 PM
Does anyone know the max tuning cap value for part#31-2658. I'm trying to use a parts 46-200 to build a transmitter and would like to use the tuning condenser, dial scale and case.
tuning condenser max value for part# 31-2658
01-26-2006, 01:05 AM
If you use it with the coil (the loop antenna in this case) from the same set, the tuning range will hold for the most part. Philco did not publish min-max values for their tuning gangs, only the max uuf values from the very early 30s sets.
You can always use a cap meter to check it anyway. Chuck Schwark, The Philco Repair Bench [Image: http://www.philcorepairbench.com/images/philog3tiny.gif] http://www.philcorepairbench.com
« Next Oldest | Next Newest »
Users browsing this thread: |
