Alignment tool for Philco 70A trimmer capacitors
I sell one for $11.50 with free shipping. It consists of a phenolic tube with a hard nylon 1/4 in. socket on the end.
see photos here: http://www.antiqueradios.com/forums/view...5&t=338288
The speaker table error?
Philco 70 antenna lead
There are currently 7076 online users. [Complete List]
» 1 Member(s) | 7075 Guest(s)
