Philco 14 Oscillator coil rewind
Good morning.
Does anyone have information on rewinding this coil? I didn't find any information on line. Specifically, I need to rewind the secondary and need number of turns and direction to wind. This radio came to me after someone else tried to rewind the coil unsuccessfully.
Cheers,
Scott
https://philcoradio.com/library/download...20129B.pdf
So which winding on #19 is open?
My radio matches this schematic: https://philcoradio.com/library/download...l.%201.pdf.
The secondary of #16 was rewound by someone in the past. The windings are sloppy and the radio won't oscillate. I don't want to assume that the number and direction of the windings are correct. I'm hoping someone can verify.
Sorry to take so long to get back to you. I don't have any exact numbers for wire ga, # of turns, direction. Too bad this coil as been damaged so that you need info at is not available. Looks like you have a couple of options. Find a parts chassis or use what info you have to rewind the coil.
If you what to give an approximation a try I would go with 38ga copper wire 5' length. Wound in the same direction as the primary. If it won't oscillate all the way to the bottom of the band add a few more turns.
Terry,
No worries. I'll try your suggestion, and search for a parts set if needed.
Cheers,
Scott
I was lucky enough to find a parts set.
For future reference, the secondary of the oscillator coil is 17 turns of #36 wire.  Wind anti-clockwise (as viewed from the bottom of the coil) beginning at the second lug on the left and winding towards the top. Connect the other end of the winding to the first lug from the left.
All is well now.
Cheers,
Scott
We'll have to get Nathan on the job to add this info to the library.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9537 online users. [Complete List]
» 2 Member(s) | 9535 Guest(s)
