41-608 speaker part number?
Besides missing the original record changer, my project 41-608 is also missing speaker and tubes. Could someone provide the speaker part number for this unit? There's what appears to be a 40-185 being parted out on eBay, and the speaker seems in good physical condition. Is this the same part, and if not, should it work for my radio, assuming the mounting pattern matches?
Thanks in advance,
Brian
Hi Brian
40-185 - 36-1479-2 or 36-1479-4
41-608 - 36-1528-4
Both are 12 inch speakers. The 1479 has a 1100 ohm field coil; the 1528 has a 1000 ohm field.
(Info from the 1946 Philco parts catalog.)
In short...Yes, the 40-185 speaker will work in your 41-608.
New member
Philco 630csx power cord
New member
There are currently 3942 online users. [Complete List]
» 1 Member(s) | 3941 Guest(s)
