Philco 77 Resistor
Greetings everyone!
I recently was given a Philco Model 77.  Cabinet is in great shape, almost looks new.  I am going to replace all of the capacitors and that shouldn't be too tough once I get past the tar.  My question is in regard to one of the wire wound tubular resistors.  The shorter one is a two-stage affair and the 800 ohm winding is open.  Looks like someone was into it before me and about half of the winding is missing, so even if I could re-connect, it would probably be the wrong value.  I was thinking about attaching a power resistor between the lugs and was wondering if 5 Watts would be sufficient, or if I should go higher?  The schematic makes reference to all resistors being 1 Watt, with the exception of the two wire wound jobs.
I was also thinking about rewinding it, but not sure what type of wire I should use or where I may obtain it.
Any advice would be appreciated.
Thank you and regards,
George B. Reisdorf
There is a thread on this from last year containing answers to your question about resistor wattage as well as other advice. You may find it useful: https://philcoradio.com/phorum/showthrea...t=Model+77
Thank you mancave! Good information.
gbr
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
