Philco coil
This is diagram for a philco 60 antenna coil is it the same for the osc coil.
Thank you.
Jim
Spring Lake MI
Not quite sure what you're asking but the answer is no. No numbers on the coil's pins
nor is there a ground connection on the osc coil.
Thanks
Jim
Spring Lake MI
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
