SHADOW METER ADJUSTMENT
According to a photocopy of the owner's manual I have for my 37-670, the shadow meter supposedly is user adjustable. The only thing I can see that could possibly be adjusted is a knurled plastic piece that also serves as the back of the coil, in front of the lamp assembly. This does not move with gentle pressure and I am afraid to exert force in case I'm barking up the wrong tree here. Can anyone help?
Yes, that is the actual coil, and it can be moved. It may be stuck after decades of not being moved, so proceed carefully.
Details here:
http://www.philcorepairbench.com/tips/svctip01.htm
Thanks,Ron! I started to gently rock the coil back and forth, and sure enough it moved -- albeit very stiffly. When I eventually get the radio together and back in the cabinet I'll be able to adjust the shadow -- assuming the coil isn't open.
I really appreciate the help.
Eric Strasen
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4801 online users. [Complete List]
» 1 Member(s) | 4800 Guest(s)
