springs used in restringing a philco tuner
I'm in need of some small springs that you use when restringing a philco tuner.I need a few, where can i buy some. Icon_confused: Thanks, give me a shout.Rich
Rich, you might try McMaster-Carr http://www.mcmaster.com/#9432k23/=9e5t56
M R Radios   C M Tubes
Slightly modified for end-hooks, ball-point pen springs may work too.
REAL cheap.
Chuck
thanks
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4796 online users. [Complete List]
» 3 Member(s) | 4793 Guest(s)
